gavin
- September 27, 2002
- Anchorage, Alaska
- '97 Explorer XLT AWD 5.0L
What is a viscous coupling?
The viscous coupling is a 2-piece part, filled with a viscous fluid and clutch packs, which is pressed together and sealed to prevent any fluid from leaking.
What does a viscous coupling do?
It provides variable output-power to the front output shaft, the amount of power dependent on how much slippage there is in the rear.
How does it work?
Under normal conditions, the inner and outer portions of the coupling are spinning at the same speed. When there is slippage in the rear axle, the rotation of the 2 parts change; since the front tires are spinning slower, the inner portion is rotating slower than the outer. Because of this variation, the viscous fluid inside gets warm (due to clutch packs "mixing up" the fluid), and becomes less fluid, and more solid. As the fluid thickens, it creates friction, by putting more force on the clutches inside the coupling. This then causes more power output to the front tires.
What are the common signs of a bad viscous coupling?
Unfortunately, there are no truely common signs. Also, the signs differ depending on which way the coupling fails.
There are 2 real ways the coupling can fail:
First, the seal can blow, allowing the fluid to leak out and into the rest of the t-case.
Second, the coupling can "sieze" up. Basically, the fluid never liquifies as much as it should, so there will always be more power output to the front driveline than originally designed by the OEM.
How do I know how my coupling failed?
In the first situation, you would notice it failed when you changed the transfer case fluid. You would also lose all power output to the front driveline, since the fluid is lost, no friction can be made to put more power to the front.
In the 2nd situation, it's a little harder to tell. Since there will always be more power output to the front, it can almost be like a driving a manual t-case in 4wd all the time. We all know this is bad on the driveline. Yes, it can cause the driveline to bind. This driveline binding could cause vibrations in the vehicle, regardless of speed.
As you can (kind of) see in this picture, viscous coupling is the large part that is sitting in the huge "cup" that goes to the rear output. The gear right behind (above) the viscous coupling, is the gear that connects the front output. The viscous coupling, gear, and bearing are also on a separate shaft than the input shaft.
The rear output is directly connected to the transmission output, via the t-case input shaft which has teeth at the rear output end, which fits between 4 little gears on a larger gear assembly.
In this pic, you can also see how the viscous coupler, gear, and bearing are (fairly) press-fit onto another shaft.
This is the just the viscous coupling.
Is there any way to test a viscous coupling?
From what I've found and read, there just may be. You would need a very flat, solid, smooth surface. You will also need a couple chunks of 2x4, and an easily-rolling floor jack.
What you need to do, is jack the rear tires off the ground. Stick a 2x4 in front of the front tires.
Start the vehicle and put it in gear. Let off the brake. At idle, the truck should not pull itself over the 2x4's with only the front tires putting power to the ground. If it does, that means the coupling has seized, and will need replaced. It will (could) be causing driveline bind which can harm other parts of the driveline. (this could be inaccurate, as this "test" I found on a site regarding the VW Vanagon which, under normal conditions, only provides ~5% power out the front)
You could also test it out on surface with less traction; ie, dirt or gravel road. If you accelerate quick enough to spin the rear tires, you should see the front tires also start to spin.
Another test, if at all possible, is during winter. If you can get in a situation where you can get the rear tires on ice, but the front on a surface with traction, you should still get the truck to pull forward.
Why does the truck creep in park, with the front driveshaft removed?
The vehicle is able to "creep" in park, without the front driveshaft, because without the shaft, the viscous coupler is able to "slip." When you have the front shaft installed, to get the vehicle to roll, the viscous coupling is moving as a whole. That is, the inner and outer portions rotate at the same speed. This cannot happen because of the parking prawl in the transmission.
Without the front driveshaft in, there is nothing keeping the coupling "together." That is, because the inner and outer portions of the coupler are not held together (essentially by the front and rear differentials), the coupler can slip. 1 half of the coupler can rotate without the other half rotating also. This slipping happens by design, of course, because the slippage is what causes the fluid to heat up and basically "lock" the 2 halves together.
NOTE:
From what I've read, it is more common for a viscous coupling to seize up, rather than leak.
Also, 99% of the information I found, was all based on the Volkswagen Vanagon. So I have no clue how much will actually compare to the Explorer's BorgWarner 4404. Although I can say that all viscous couplings have the same basic parts and same basic working-concept, so it should be similar enough.
Where I got most of this info:
The Viscous Coupling
Viscous Coupling and Couplings In The Vanagon Syncro T3
How Differentials Work
Viscous coupling unit - Wikipedia
I also got some of the info based on the Jeep's Quadra-Trac which also uses a viscous coupling for AWD-capability.
Only last note: I've also read many many times that these viscous couplings do have a limited lifetime. I believe the Vanagon said to expect around 100k miles or so. And apparently some VW 4-Motion cars have a life expectancy of around 40k miles. (Technical Q&A | Porsche Club of America)
There haven't been too many posts on the viscous coupling, and especially none with a whole lot of real info. And due to issues with my truck, and the viscous coupling being the only thing that has not been replaced, I did a lot of research. Figured I might as well share my findings for anybody else who may find this useful
How does it work?
NOTE:
