Schraeder valve stuck in low side port
93TwotoneXLT
Evansville, In
1993 XLT4x4
So I tightened down the valve a little too much I think, and now the valve is stuck in the low side port because the top set of threads sheared off. So my question is, How do I get this thing out now? Do they sell a special tool that I can use to get it out? Anybody know any tricks that can help me out of this situation? Any help is greatly appreciated!! :)
shamaal
Friensdwood, Texas
91 Mazda Navajo
The trickiest guy I know for A/C is Glacier991.
I've never busted a schraeder valve, and I can't visualize any sheared off threads.
93TwotoneXLT
Evansville, In
1993 XLT4x4
Anyone have any ideas?
parli22
Loco en cabeza
New York
92 Explorer UNEDDIE
I s it the scrader valve or the port the NG.
IF the Valve you can get a new one .75 cents but your looking about 35.00 For the tool
20.00 for the tool and 15.00 for the adapter
tool you can get from any A/C supplier by you
as for a Scrader vlave remover w/ valve
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
93TwotoneXLT
Evansville, In
1993 XLT4x4
Thanks for the replies guys. The valve that is stuck is the new one that I put in, after I took the old one out the with valve removal tool. Unfortunately, the new valve is of cheap design and when I tightened it down the top set of threads just sheared off from the base. I went ahead and charged the system with 134a and so far it has held the charge without leaking out, so I may have gotten lucky. If it does start leaking then I may take it to a tire place and have them remove the valve for me. I think that I may have air trapped in the system because it is not getting very cold, just cool enough to keep you from sweating. Of coarse, it is 100+ degrees outside right now :eek: It only took 24 oz of 134a and 8oz of pag oil for it to show a full charge on the gauge. I will probably take it to a A/C shop and have them evacuate the system properly and make sure that I have a proper charge when finances get a little better. Thanks :)
B Is the Schrader Valve "Standard"... or "JRA"... which one? A/C & Heater systems - HVAC 1
P A/C compressor high pressure release valve - what "non-captive" means? A/C & Heater systems - HVAC 0
K Heater Control Valve 101 Please A/C & Heater systems - HVAC 11
T Coolant bypass valve questions A/C & Heater systems - HVAC 1
B High pressure port valve leaks A/C & Heater systems - HVAC 7
F Replacing Schrader valve under pressure A/C & Heater systems - HVAC 0
S Heater control valve issues. A/C & Heater systems - HVAC 4
K Heater control valve installation help is needed. A/C & Heater systems - HVAC 3
1 stuck schrader valve on Fresh rebuild A/C & Heater systems - HVAC 3
G Low side valve location? A/C & Heater systems - HVAC 3
1 orifice valve first gen. A/C & Heater systems - HVAC 1
B AC high - low valve locations. A/C & Heater systems - HVAC 8
C Leaking heater bypass valve at max AC A/C & Heater systems - HVAC 5
A Where is orifice valve on 98 ford explorer A/C & Heater systems - HVAC 3
M Air Pressure Relief Valve A/C & Heater systems - HVAC 2
J Need Info on port valve for A/C. A/C & Heater systems - HVAC 12
P Expansion valve? Where is it? A/C & Heater systems - HVAC 1
C A/C Lower Pressure Valve: Possible Leak (?) A/C & Heater systems - HVAC 1
O A/C Clutch Hit & Broke High Side Valve A/C & Heater systems - HVAC 3
V Can someone tell me where the AC coolant recharge valve is? A/C & Heater systems - HVAC 3
S Location of Radiator Drain Cock Valve 94 Explorer A/C & Heater systems - HVAC 8
S 1991 Ford Explorer Heater Bypass Valve Installation A/C & Heater systems - HVAC 8
T Wheres my low side schrader valve? A/C & Heater systems - HVAC 4
F Heater core valve? A/C & Heater systems - HVAC 2
9 Leaky low side valve A/C & Heater systems - HVAC 1
J a/c schrader valve guts A/C & Heater systems - HVAC 2
S Expansion Valve A/C A/C & Heater systems - HVAC 10
T 2001 Explorer Sport 4.0 SOHC Vents stuck on. A/C & Heater systems - HVAC 1
D 98 explorer blower stuck on high A/C & Heater systems - HVAC 3
S 03 Explorer rear A/C mix door stuck? A/C & Heater systems - HVAC 0
N A/C stuck ON and battery dies A/C & Heater systems - HVAC 1
gmanpaint A/C check ball is stuck! A/C & Heater systems - HVAC 0
S A/C stuck in defrost A/C & Heater systems - HVAC 13
F -98 Explorer heater stuck on warm A/C & Heater systems - HVAC 5
Similar threads
