interscope8
- April 22, 2010
- Purdue University
- 2001 Sport Trac 4x4
Alright, I just pulled another all nighter doing homework and am ending it at 5:45 am with this thread! In between relentless homework assignments and exam prep, I have been cruising around looking for components to my audio system. I thought that I should start a build thread for it because I know how many dreaded Sub Enclosure questions we get in this part of the forum. So here goes...
CURRENT SETUP
Right now I'm on a pretty limited budget set up. I spent right around $350 for everything. It doesn't sound terrible, and I'm sure one could do better with more patience than I.
I started with getting my Head Unit from crutchfield.
I bought a CZ500 for $80 shipped to my door, it was 60% off at the time and they no longer carry it, here is a newer model almost equivalent:
http://www.crutchfield.com/p_020CZ401/Clarion-CZ401.html?tp=5684&nvpair=FFBrand|Clarion#overview-tab
I strongly recommend getting the Head Unit from Crutchfield, they give you all your mounting hardware needed for it. Mine came with the adapter for the speakers and subwoofer as well as the mounting hardware.
Only difference from what I can tell is mine has built in Bluetooth.
After purchasing this a sale over at sonic popped up and I got my speakers and amp for $220 shipped.
I got a Hifonics 4 channel 440 watt amp and 4 Hifonics 6x8 speakers.
And finally I picked up the under-seat box from ebay that everyone knows about.
Link: http://www.ebay.com/itm/Ford-Explor...ultDomain_0&hash=item53e6284d8a#ht_854wt_1037
And I picked up my sub from a buddy for $40:
Its an MTX 550 Thunder. It had a sister sub and it was sold to another friend who has it ghetto rigged into his Ranger.
I wired it up using a 4 gauge wiring kit from autozone, I actually got it for free using the points I had on my card
Analysis
Today it all sounds great, however, the sub was used and abused... its starting to rattle pretty bad. Another flaw is that I used 2 channels of my amp for my rear speakers and 1 for my sub, my front speakers aren't powered from my amp. You can't tell much of a difference, I unplugged my sub for a drive and could notice one when bass hits, my rears would put out more of a thump than the fronts...
All this being said, I figured it was time to upgrade.
Next Setup
I decided 1 wasn't enough and am getting the behind the seat 2 10's box.
Link: https://www.soundoffaudio.com/item.cfm/id/2428
I am going to blow up my current sub with my .223 and some tannerite and put in 2 Pioneers I found the other night.
Link: http://www.sonicelectronix.com/item_11097_Pioneer-Shallow-Mount-TS-SW251.html
These are shallow mounts and I figured 2 shallow mounts would sound marginally better than 2 standards and a helluva lot better than what I have now. That and these are dirt cheap for peaking at 800 watts.
Im going to run power to my front speakers with my current amp and want to power the 2 new subs with this.
Link: http://www.sonicelectronix.com/item_27288_RE-Audio-XT-1600.2V3.html
I have a friend with 2 20's in his old firebird and an RE amp powers them both and it seems to work ok. I usually don't buy into these lesser known names when it has anything to do with my trac but RE seems to be legit. This is also pretty cheap. With both subs hooked up I could run the RMS for the subs at 4 ohms or 400 watts at 2 ohms and not risk blowing anything up. Seemed like a good safe fit.
I plan to run 2 Gauge power wire for the RE amp and will be mounting both amps under my rear seats unless another spot pops up during installation.
Idk if it's because I'm super tired, bored, or trying to be helpful (or maybe a mixture), but I figured this thread would help out others who are planning or wanting to upgrade their audio system.
As I knock this stuff out I will add pics and How-To's.
If you have questions post up, my inbox is almost full so if u PM me let me know on here too!
CURRENT SETUP
Analysis
Next Setup
