- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
This is good info i didn’t know. Is it only the Limited’s?
The higher option models should all have the high amp alt.
I learned that when I bought my 99 SOHC from a JY, it had a few parts missing, and they found another alternator for it. The one they gave me was a 3G and wouldn't work on the SOHC, that and the 302 use a 4G unit. So it was a spare alternator until a year later my 91 ran the battery down. I didn't fix the old alt, I just bolted on that spare.
The under drive pulleys for the 4.0 aren't as extreme as old Fox Mustangs(I have those pulleys on my 91 HO 302(that required a better alternator)). You should be fine with the 4.0 kit, just watch the coolant temps idling in high heat, and the charging voltage with lots of things turned on.
An electric fan should be run by a PWM controller, they apply far less current when turning on the fan, instead of the high current shock of a simple relay.
