Seafoam Engine Cleaner
JoshEwa
josh79701@gmail.com
I put a full can in my gas tank, and also 1/3rd in my oil and 1/3 in my vacuum line (as directed) my 07 xlt was running great so I did not notice anything but it made me feel good :)
** make sure you change your oil right after (30-50 miles) I also suggest changing your spark plugs as well.
P Seafoam....yeah I know..... 2001-2005 Explorer Sport Trac 12
S Sport Trac Engine Swap 2001-2005 Explorer Sport Trac 3
S Sport Trac Jr. engine,body bush,Manual Tran.....quest... 2001-2005 Explorer Sport Trac 62
M engine missing and tranny won't shift 04 explorer 4.6 2001-2005 Explorer Sport Trac 0
P Engine Oil Recomendation 2001-2005 Explorer Sport Trac 4
D Engine Swap - Now PATS won't let me start? 2001-2005 Explorer Sport Trac 18
R 4 cylinder engine swap? 2001-2005 Explorer Sport Trac 23
T Engine Air Intake Hose hole? 2001-2005 Explorer Sport Trac 3
R Questions about engine swapping with 2010 mustang 4.0 2001-2005 Explorer Sport Trac 2
K 2001 Engine Bay 2001-2005 Explorer Sport Trac 1
A 4.0 V6 Engine Start/Stalls 2001-2005 Explorer Sport Trac 2
F Introduction and engine troubleshooting 2001-2005 Explorer Sport Trac 2
B 4.0 Reman Engine Info 2001-2005 Explorer Sport Trac 1
koda2000 I did something dumb (re-titled 4.0L SOHC engine tear down) 2001-2005 Explorer Sport Trac 61
S Engine lights on no key in ignition 2001-2005 Explorer Sport Trac 20
koda2000 SOHC Engine Removal/Rebuild/Install - Done! 2001-2005 Explorer Sport Trac 334
2 4.0L Engine Year Compatibility? 2001-2005 Explorer Sport Trac 12
X 04 Sport Trac, replaced engine once already 2001-2005 Explorer Sport Trac 2
D Engine smoking... 2001-2005 Explorer Sport Trac 6
H Explorer Sport Trac P0320 engine stalling 2001-2005 Explorer Sport Trac 0
S Solved Engine overheating. 2001-2005 Explorer Sport Trac 5
P Other engine oil leak. 2001-2005 Explorer Sport Trac 4
D Engine fitment 2001-2005 Explorer Sport Trac 12
S 2003 Sport Trac oil on back of engine driver side. 2001-2005 Explorer Sport Trac 2
A Engine turns over and runs for 2 seconds but immediately stops 2001-2005 Explorer Sport Trac 0
J Engine break down after 3000 rpms 2001-2005 Explorer Sport Trac 13
K 2003 Explorer Engine Number 2001-2005 Explorer Sport Trac 4
J Engine swap 2001-2005 Explorer Sport Trac 2
J Engine Misfiring on Bank 1 2001-2005 Explorer Sport Trac 4
B Sport trac not starting engine 2001-2005 Explorer Sport Trac 2
W Engine knocked for 60 seconds then went away. 2001-2005 Explorer Sport Trac 6
E 01 Sport Trac engine shaking 2001-2005 Explorer Sport Trac 0
W Need help identifying Engine Parts 2001-2005 Explorer Sport Trac 2
T 01 Sport Trac Flashing Check Engine Light 2001-2005 Explorer Sport Trac 16
J Engine Misfire 2001-2005 Explorer Sport Trac 6
P Engine Compartment Gound Wire...just hanging. 2001-2005 Explorer Sport Trac 2
All out Need to replace my engine 2001-2005 Explorer Sport Trac 7
W 2001 Engine Noise? 2001-2005 Explorer Sport Trac 8
S Vacuum question after engine instal. 2001-2005 Explorer Sport Trac 0
R Sport trac needs an engine 2001-2005 Explorer Sport Trac 3
Paul Fithian Oil Filter Confusion - Job 1 Engine 2001-2005 Explorer Sport Trac 3
J Sport Trac engine rattle after replacing timing chains 2001-2005 Explorer Sport Trac 5
F 2003 Explorer engine swap issues 2001-2005 Explorer Sport Trac 7
E Fuel smell after engine is turned off 2001-2005 Explorer Sport Trac 5
B 2001 Explorer Sport trac engine shut off 2001-2005 Explorer Sport Trac 3
P 2004 Explorer timing cassettes replaced, engine just "spins" 2001-2005 Explorer Sport Trac 11
P 4.0l Engine Timing Chain Tensioners, Replacement Schedule 2001-2005 Explorer Sport Trac 31
S 2002 sportrac engine replacement using later year 2001-2005 Explorer Sport Trac 0
W Engine fit for 03 sport trac 2wd 2001-2005 Explorer Sport Trac 5
G A better engine for a 2003? 2001-2005 Explorer Sport Trac 14
Similar threads
