Second Gen MPG Numbers
koda2000
x
But But I want 24mpg
LOL - I think I saw 24 MPG on my driver's message center once (for about 5 seconds) on a trip up super flat Interstate 75 to Chattanooga with a strong tailwind. Not a realistic goal.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
I think that's why it's out now in just one model, and not the Explorer ST also. The Explorer buyers will push the limits faster and be less forgiving. Maybe if it works out well, the Explorer will get it next, and then maybe the new Mustang. I just learned it supposedly adds 1000lbs to the truck, that's a bunch if it's true. The tow rating is down by about 900lbs, from the extra weight of course.
donalds
Location
Stem
Nc
1999 ford explorer sohc
I was joking lol
fast_dave
East Bay - Nor Cal / PRK
'98 Spt 4.0 OHV 5 spd 4x4
toypaseo
Flunked daycare
outside shovelling snow
................ 96 XLT ™
and... now back to 19MPG :rant:
koda2000
x
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
You can get great mileage any time ... that you are going downhill. Just watch the display jump to 90mpg+ going down a hill, after you let off the gas.
2 Second Gen Cabin Air Filter Stock 1995 - 2001 Explorers 5
E Second Gen turns barber shop into drive-thru Stock 1995 - 2001 Explorers 3
ld50 Second Gen roof racks same as first Gen? Stock 1995 - 2001 Explorers 0
I Second gen lean codes and fuel pump malfunction Stock 1995 - 2001 Explorers 0
S My first second gen. Stock 1995 - 2001 Explorers 5
S Looking to buy a second Gen X soon Stock 1995 - 2001 Explorers 12
N getting a used second gen Stock 1995 - 2001 Explorers 7
R might buy second gen, need advice Stock 1995 - 2001 Explorers 16
C Need a canter cap for a wheel? (second gen) Stock 1995 - 2001 Explorers 3
B Taillights for Second Gen Ex Stock 1995 - 2001 Explorers 1
U How many vin codes for the 5 liter second gen X Stock 1995 - 2001 Explorers 0
S Fastest second gen?? Stock 1995 - 2001 Explorers 2
Charlie How to install a Mountaineer roof rack on your Second gen X Stock 1995 - 2001 Explorers 3
F Help! Brakes suddenly go out and I frantically pump them and car accelerates for a second. dude am I CURSED Stock 1995 - 2001 Explorers 14
sattech2000 Snapped Second shift tube in a year - what's causing it? Stock 1995 - 2001 Explorers 5
M Replacing cat. converter on 1995 Ford Explorer 146,000 miles , second owner Stock 1995 - 2001 Explorers 0
J expanding the range of a 99 sport, second fuel tank? Stock 1995 - 2001 Explorers 11
J 2001 xls 4.0 sohc issues after second timing guide replacement. Stock 1995 - 2001 Explorers 1
D Just bought my second Explorer Stock 1995 - 2001 Explorers 21
The Project My second find of the year! How rare is it? Stock 1995 - 2001 Explorers 18
D 2k explorer slipping first and second, O/D LIGHT BLINKING Stock 1995 - 2001 Explorers 3
A transmission not shifting over the second gear Stock 1995 - 2001 Explorers 1
N 95 explorer lost second gear?? Stock 1995 - 2001 Explorers 4
J 4r70w stuck in second gear od light flashing Stock 1995 - 2001 Explorers 3
M starter engages for a second and quits. Stock 1995 - 2001 Explorers 24
S transmission jerking into second Stock 1995 - 2001 Explorers 6
H Second a/c compressor is about to die Stock 1995 - 2001 Explorers 2
E Second row in 01 sport Stock 1995 - 2001 Explorers 4
D Second alternator install Stock 1995 - 2001 Explorers 10
ahodges Engine Cuts out for Split second Stock 1995 - 2001 Explorers 11
T second pcm for trans? Stock 1995 - 2001 Explorers 1
C Second Gear Flare Stock 1995 - 2001 Explorers 1
N Second Explorer with Drivers side air vent not blowing Stock 1995 - 2001 Explorers 8
B Want to add second Transmission Cooler Stock 1995 - 2001 Explorers 3
A Would like a second opinion (fuel pump) Stock 1995 - 2001 Explorers 3
D Transmission won't shift from first to second Stock 1995 - 2001 Explorers 4
V CV joint Mathmatical stand point second try Stock 1995 - 2001 Explorers 3
A Split second chug.... Stock 1995 - 2001 Explorers 0
C Second set of rear shocks Stock 1995 - 2001 Explorers 9
J adding a second alternator Stock 1995 - 2001 Explorers 14
V second brake resivor? Stock 1995 - 2001 Explorers 4
M Rough gear switch to second Stock 1995 - 2001 Explorers 0
A rattling one second after start up Stock 1995 - 2001 Explorers 7
L Ford Dealership...need second opinion! Stock 1995 - 2001 Explorers 50
B Stalling/no start on first try, fine on second Stock 1995 - 2001 Explorers 3
E Best starter for 2nd gen Stock 1995 - 2001 Explorers 12
E 2nd gen hatch wanted Stock 1995 - 2001 Explorers 8
J 2nd gen 01 cluster upgrade question Stock 1995 - 2001 Explorers 2
GrayGhost96 Using first gen (91) rear glass and hinges on 2nd gen (96) Stock 1995 - 2001 Explorers 5
T 2nd gen Explorer 15" spare tire Stock 1995 - 2001 Explorers 9
Similar threads
