For my 10,000th post I guess I will start my SAS registry now that the truck is done.
Section525's SAS Build thread
Specifications
Front
'83 Wagoneer LP D44
JCW 5-leaf Springs (Stockers)
Detroit EZ Locker
Spicer 4.88 gears
Warn Premium Hubs
Rock Equipment Super Boy Howdy Fabricated Knuckles
Sky Manufacturing High-steer arms
Pro Comp MX6 Shocks
Rear
Stock 8.8 SOA
Sierra 4.88 gears
Detroit EZ
Spidertrax 5x4.5 to 5x5.5 adapters
Stock shocks
The Build
The LP D44 came out of a 1983 Jeep Wagoneer. I was there when the guy pulled it out from under the Jeep. It was nice to see the condition of the donor before buying the axle.
I began the tear-down of the axle and everything looked good inside.
I used TT Fab Works SOA perches for the D44
Here is the bare housing ready for hot tanking.
After the hot tank bath, it went into the blast cabinet to get even cleaner
This is what it looks like when it's cleaner than it was when the factory got it!
I built the front spring hangers out of 3.5" square tubing (.250 wall). That make the inside width 3". Good for any spring you would every want to run.
Make sure you cut the side off with the seam. Drill some holes. Round the edges and you have a nice spring hanger.
Looks like something you would buy off the shelf but for a 1/4 the price. I think these ended up with a cost of about $2 a piece.
For the front crossmember I used 4"x6" .250 wall tubing. I angled and capped the ends for bling factor.
Also to completely seal the crossmember so no water or mud would end up inside.
I added some speed-holes to keep my top speed in the 140s.
Here it is mounted in place. There's pretty much only one place it can go between the body mounts and frame horns.
Specifications
Front
'83 Wagoneer LP D44
Detroit EZ Locker
Spicer 4.88 gears
Warn Premium Hubs
Pro Comp MX6 Shocks
Rear
Stock 8.8 SOA
Sierra 4.88 gears
Detroit EZ
Stock shocks
The Build
