Security alarm, auto unlock, parking lights, door ajar, oh my!
Weekend
Cincinnati
2002 Explorer XLT 4x4
The first thing I noticed was a door ajar signal while I was driving... sometimes a stutter of locking as if the car was just placed into drive and the auto locks were engaging. The next thing I noticed was the alarm going off every now and then... and now it's consistent -- almost every night and/or in the parking lot when I am shopping.
To me all of those pointed to a bad door ajar light... but recently I've seen two new behaviors that have me stumped:
1) If I take the key out of the ignition, open the door, and then press lock... the doors automatically unlock again as if the explorer thinks the keys are still in the ignition
2) If I have auto headlamps turned on, I notice my parking lights cycling on and off
Should I keep troubleshooting the door ajar switch, or does this sound like some kind of control module going bonkers?
Luke G.
Murray, KY
2002 Explorer 4.0
I had the same exact problem with my 2002 Explorer. I troubleshooted which door ajar switch was faulty. 8/10 times its the driver side door. For the new behaviors, it sounds like its related to the door ajar switch.
LMHmedchem
2002 Explorer XLT v8
I always start with anything I know needs to be fixed. You know the door ajar switch is a problem, so fix that since you know you need to do that anyway and see if it helps with anything else.
There are lots of things that are affected by broken wires in the door boot, so that is somewhere else to look if fixing the switch doesn't clear up the rest.
LMHmedchem
toypaseo
Flunked daycare
outside shovelling snow
................ 96 XLT ™
Unsure if it is the same deal as in my 96, but I had issues with the factory alarm going off at random times. I replaced the battery under the hood, and that solved my problem.
WildBill798
Elizabethton Tn.
2002 Ford ExplorerXLT
My '02 is also having some of the same issues, door chimes, door locks etc. Sometimes just barely touching the brake pedal seems to do it. But when I get about a half mile down the road, it never does it again. ... unless I stop and turn it off.
Lauri salow
Vina Alabama
2003 ford sport trac
My '02 is also having some of the same issues, door chimes, door locks etc. Sometimes just barely touching the brake pedal seems to do it. But when I get about a half mile down the road, it never does it again. ... unless I stop and turn it off.[/
Lauri salow
Vina Alabama
I'm having the same issues with my 03 sport trac plus it happens every time I hit the brakes the locks act up and interior lights come on and buzzer goes off!
Weekend
Cincinnati
As it turns out, I had two problems. The security alarm and the random door lock/unlock problems were fixed with a new door ajar switch.
These:
Went on for a while, but eventually my battery started underperforming. A new battery ended up curing both of those... I assumed it was a control module going bad, but I don't often think about a control model being flaky because it wasn't getting enough voltage -- but this seems to be the case here.
Lauri salow
Vina Alabama
These:
I am at my wits end with this it's like looking for a needle in a haystack
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
As mentioned by toypaseo and Weekend above, weak or faulty batteries are KNOWN to cause MANY different electrical and lighting issues and gremlins with Explorers including ST's. First thing to do is call around and find an auto parts store that can LOAD TEST test the battery
as a free service. Weak battery symptoms aren't just limited to slow cranking, no start, or dim lighting. I've even seen dash lights on ST's going berserk due to a faulty battery. Test the battery and report back.
Hello my name is Lauri, I hope you can help me! When I put on the brakes of my 2003 explorer sport trac it unlocks and locks, interior lights come on and off, door ajar light blinks on and off and a buzzer comes on and off! Can someone help me
Lauri salow
Vina Alabama
I have a new optima yellow top battery
Lauri salow
Vina Alabama
I have a new optima yellow top battery in my sport trac
Lauri salow
Vina Alabama
I have a new yellow top optima battery
07gtman
Chicago IL
2005 Mountaineer 4.6 AWD
i have fixed my door ajar light with wd40 spray a liberal amount on the door latch on the edge of the door open and close it several times you may have to figure out which door it is.. my 02 mountaineer does this every winter sometimes its a front door sometimes a rear i just do all of them now..
Lauri salow
Vina Alabama
Thank you
07gtman
Chicago IL
if the wd40 does not work swshawaii is right about the gremlins some new batteries arent allways good batteries..
