sharonis3
- June 4, 2001
- New Brunswick
- 08 Eddie V8, 02 Ltd V8
Hi:
Daughter had the truck last night.Called and said there was a loud, steady electronic buzzing under the dash and if she shut the truck off - the horn would blow after a short period of time. (which I assume is the security\key system horn)
Earlier this week, I noticed that if I turned the wheel to extreme, when backing up - the horn might blow once...
So after I got the truck home last night..... the buzzing is from a big black module, under the dash, above the drivers left foot (to the left of the steering shaft) What is this ????
Then the last thing I noticed last night was that for the last full turn of the wheel to the extreme left - I could hear a slight dragging noise from the steering wheel. Sounded like the dragging sould was just under the airbag.......(brushes screwed up for the steering wheel switches ?? - could this cause the symptoms)
Help - I am going to troubleshoot later this afternoon - all help would be appreciated......
I am good on mechanics, but have not messed with the security system....
