- January 26, 2004
- Mechanicsville, Virginia
- 2004 Acura TL
Well, There is that little cricket that everyone knows of when the belt goes bad or loses a tooth or something weird. Anyway, It just happend recently, the weather has been extremely weird (63 one day, 32 the next)....so I blamed the problem on the weather. Well - now the squeeking is getting a little worse and I was going to replace the belt soon, but now when I spray lube on it, it doesn't want to go away. I've been trying to just spray the belt so I can either isolate if its the belt or the tensioner. I believe I'll replace the tensioner sometime this week - but I'll get someone in the shop to do it cause I believe tensioners are under warranty. I have one more month left on that thing - I'm gonna use it up! I go into the shop I work at the end of March for Inspection, so believe me - if anything has a slight of play in it or anything, I'm getting the warranty to replace it! But the main reason for the post is to figure out if anyone else has had a problem with the tensioner -- I only have a little under 71K on it.
-Drew
-Drew
