service engine soon, 4x4 high, 4x4 low lights flashing | Ford Explorer Forums - Serious Explorations
Bdaniel
2004 Ford Explorer EB
so i got in my car to drive home and the service engine light started flashing shortly after i left work. I stopped in at autozone and when they hooked up the diagnostic tool it could not connect to the OBD. He said it could be a bad fuse, or the computer is about to die and will be barely driveable after the exploder goes into power saving mode.
When i got back in to drive home not only did the service engine light continue to flash, but the 4x4 high and 4x4 low lights began to flash at the same time for a few flashes and then stop for a bit and then begin flashing again.
any thoughts on what the problem is or how to fix it?
For the obd connector check to make sure fuse 24 is good.
