Service RSC, ABS | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
Service RSC, ABS
Boozel
McVeytown, PA
2008 Mercury Mountaineer
I just joined, and I'm at my wits end with my 08 Mountsineer. The Service RSC came on intermittently awhile back, I did nothing and it went away. I had a wheel bearing go bad and the ABS light came on and off. Changed the wheel bearing, now RSC is on, ABS is on, stability light is on, and power is reduced. I thought I over-tightened the axle nut, so I backed it off, and there was no change. What did I do wrong?
First you need to get the abs codes pulled. Was it the front or rear bearing that went bad? Lastly did you check and make sure the abs sensor is plugged in?
I had all those pop up when I had a bad front abs sensor..... a code reader will show you if all 4 sensors are reading a speed
I'm going to the garage this afternoon to get codes pulled. It was the drivers front and yes I checked the ABS sensor plug.
