copdodger
- January 4, 2010
- Houston
- 02 XLT
okay, so i have driven long enough with no overdrive to finally decide to fix it. what my questions are
1) do i have to drop the trans. to fix this, or can i just remove crossmembers and lower the transmission to accomplish what i need??
2) other than servo bore kit, should i buy replacement servos??
3) what should i use to drill out servo with?? air tools, or just cordless drill??
4) since i have never worked on a transmission, what else should i keep an eye out for?? how to tell broken bands, or worn torque conv., other things that might be bad, or broke
symptoms go as follows: code thrown is p0775 - car shifts decently through all gears, maybe a little jerk from 2-3, but all in all i feel like its good. from 4-overdrive, the first time from a cold start, it will shift, but once warmed and tries to shift into overdrive again, it will just bounce back an forth until the o/d light flashes. so now i just turn o/d off, and i cruise fine. recently i have been making long trips and get 18 mpg highway, i decide its best to fix this problem and hopefully gain some mpg's back. i just hate this problem.
i have done enough research to feel like this is caused by a worn overdrive servo, but have been leary to attack it by myself since it could be something else (servo block, broken bands, whatever), now i am finally financially able to attempt to get this done myself, but would like to be able to do this in one fell swoop.
