Mikey*TX
- February 3, 2020
- Skunk Hollow, TX
- 2021 ST Star White
Don't try this at home ..........
Hey Mike. Can you confirm what that light bluish rectangular item is in the center of the lower opening? Some sort of sensor?
Thank Mike. On the 5th gen it was located on the driver's side on the same level but behind the plastic.That is the radar for the system that slams on the brakes if one gets to close to the vehicle in front. Also, using the intelligent CC, slows down the vehicle. It is actually black. The lighting is what made it look blue in the other picture. The second picture is the back side of the front clip. The protective rectangle is visible
Can you get a 45* pic from the side rather head on. I actually quite like it but would love to see it off center.
That looks awesome!!View attachment 314910
If you need a right angle shot, let me know. I will drive back up and take one. It started raining just as I took this.
When you say not running right what type of symptoms do you have?I can't wait to find out what's gone wrong under the hood. It was running just fine until I hit a small pavement splice in a construction zone. Knowing it was there, I'd already slowed down from the posted 55 mph to around 40. I am betting it is a connector issue in the big harness that runs along the right side to the front of the engine compartment.
