KA3NXN
It's HER truck
- October 28, 2008
- Arvoinia, VA
- 2002 Explorer XLT, 4.6L
- Callsign
- KA3NXN
Hey Guys,
I was in the process of taking things apart to replace the timing chains and all related components because I had a horrible chain slap that the right side chain was rubbing so much that it made a hole in the timing cover.
My question here is the about making sure that I am timed properly before I try and do more damage than already has been done.
The truck was running fine when I took it apart to do the job . When I took the cover off I am going to assume the the the engine was still in proper timing. The part that has me boggled is the black links on new chains will not line up with the timing marks on the sprockets.
One person told me to take the plugs out of the engine and tighten all the new timing components properly and just turn the engine by hand to see if it locks up anywhere. Is this good enough to make sure I didn't screw anything up?
What else can I do to make sure the timing is set properly?
What am I doing wrong?
