slag
- November 27, 2001
- Lawrence, Kansas, home of the JAYHAWKS
- vehicleless...
Working on my second 91 X, I am getting several Check Engine Light codes at once.
They are..
code 21--ECT out of range OR EDIS fault-CPS problem
code 24, ACT Sensor (brand new just replaced), or, EDIS fault-coil 1 primary circuit fault
lastly,
code 66--MAF sensor or VAF sensor-voltage too low, OR, transmission oil temperature sensor signal voltage is too low.
I bought a new coil pack but have not installed it. I dont think its going to fix the problem... What about replacing the CPS.. could that cause both code 21 and code 24 errors? What else should I be looking at? A new ignition control module is $144.00 (ouch). I dont want to be throwing money at this problem, but not really sure what is at fault here....
And the last one, I am going to clean the MAF and see if it clears up.
They are..
lastly,
