Sewing project advice is needed. | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
College Student
Indinapolis, IN
'03 EB
So I recently learned how to properly use a sewing machine. So, i'm thinking a decently easy project that i could make would be one of those soft cushy laptop case things, any advise or ideas on what i should use for material and softening material?
this sorta thing
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
I'm sending a link to this thread to Zukman, or actually Mrs Zukman (Sue). She does a lot of sewing.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Your thread was renamed & moved into the Explorer lady's section. It should get more attention in this section than in the electronics section. Soft foam material is fragile, so I would suggest a durable edging around the sides. It's not really necessary but it will extend the life of the bag. You could use a second color for the edging to add to the style of the bag. Is the zipper on the top or around the entire bag?
College Student
Indinapolis, IN
'03 EB
Just on top, and are you saying to put a piping (like automotive seats) on the exterior? And thank you I didn't really know where to place the thread at.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
The edging would go around the outer perimeter. This is the plan:
1. Sew the material around three sides (exclude the top where the zipper attaches).
2. Turn it inside out then use a roll of edging material to connect on the top of those three sides.
3. Turn it inside out again, and sew the zipper.
4. Turn it inside out again which is the correct position since it's now finished.
It's might be hard to get, but they make an edging attachment foot. It's not really necessary but it makes the job easier.
College Student
Indinapolis, IN
'03 EB
any ideas on what material would be soft yet not scratchy, and what for the inner padding
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Check a local fabric store. By the way, what kind of sewing machine do you use? Don't set the stitch length too close, and leave the pressure foot set at medium. A medium needle would be fine too. A very thin needle might break while a thick needle is only used for thick, dense material such as heavy wool which is used for a coat.
College Student
Indinapolis, IN
'03 EB
well i was using a white i think, my dad has a large one at work that they just paid to have repaired and it still doesn't work but i'll most likely be using my mom's, not sure one bit what make or model it is
BrooklynBay
Staff member
Moderator
Brooklyn, NY
College Student
Indinapolis, IN
'03 EB
The two I will have worked with are residential but the still broken one is commercial
