sh*tty idle problem | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
sh*tty idle problem
dmc80
chicago
99 xlt ohv
I have read as much as i can on this but still hav'nt resolved..99 ohv already replaced plugs,wires, dpfe sensor and tubes, coolant temp sensor, pcv valve, replaced maf, and clean iac, had injectors cleaned. does the lower intake fix apply to the ohv's? its about the only thing i hav'nt done.
Frustrated to no end!:mad:
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
The IAC cleaning is kind of tricky to get right I have found-
pay attention to the rod and spring which slide back and forth-you want them to be free of dirt, and the rod to slide freely-
with spring on the left, while looking inside it-push the rod to the right. now, clean it until the spring will push it that far on it's own. If it will not, then you will need a new IAC valve.
Oh
does the "check engine" light illuminate?
does it illuminate with the rest of the bulbs during the key on test?
dmc80
chicago
99 xlt ohv
CEL was on before cleaning and hasn't returned, but hasnt been driven much..I did notice the dirt inside and will clean more thoroghly. CEL cleared cuz neg cable removed for about 3 hrs.
marragtop
balt, md
91, 92, 95, and 2000 xlts
The IAC may not throw a CEL. I'd consider replacing the IAC before doing the intake gasket.
team
describe your crappy idle please
dmc80
chicago
99 xlt ohv
Idle doesnt matter anymore, just bought iac at autozone and wrecked in to a tree.. good ol chicago sno storm..now i need a bumper, grill and hood
dmc80
chicago
99 xlt ohv
i'm fine.. just pissed i was close to figuring out my issue and now i cant get my hood open
dmc80
chicago
99 xlt ohv
UPDATE!!!
Finally Rebuilt front end with new bumper, grill and Hood($350). I replaced the iac and also replaced the maf again. Ran like new for two days. Cel came on again. Even though its running good I have emission tests in my area so it needs to be fixed. I'm assuming its the same codes and will have them checked when i return my core maf. With my OHV, is the intake gasket replacement usually the tops or bottoms, not trying to be lazy, but its only 12 degrees out now and my garage is not the warmest place.
