shaking feeling , od light on..
dtl 2k2 sport
stafford Va
2002 SPORT
Ok od light is flashing on my 98 sport. Automatically I'm thinking the stupid transmision is falling out. But drive it around and the light will go off and shift fairly smooth. But highway speeds the Rpms are at 3k near 70 mph. Im pretty sure I'm destroying what's left of this transmission. But its a toy and had 145k when last checked.
Today I was playing around in a few muddy backroads and going down the highway I notice when I stomped on the gas the Rpms dove to 2k and its shaking. Never lost power but the girl didn't like all that heaping 4.o power. So od light flashes but not constant and now my truck is convulsing. Any ideas?
Dave.
G Transfer Case Vibration/Shaking Transmissions & Transfer Cases 2
C axle shaking Transmissions & Transfer Cases 5
K Whopping sound & feeling when turning in 4x4A and 4x4H Transmissions & Transfer Cases 0
3 Trans slipping/grinding feeling in 1st gear Transmissions & Transfer Cases 1
C 03 Explorer is light flashing and popping into 4th Transmissions & Transfer Cases 1
A OD light Transmissions & Transfer Cases 3
O 2000 v6 trouble shifting and OD off light blinking. Transmissions & Transfer Cases 1
T 1995 Explorer 4wd speedometer not working OD light flashing Transmissions & Transfer Cases 2
C 2002 explorer p0741 code. 5r55w transmission problems. OD light flashing. Transmissions & Transfer Cases 2
B Wrench light Transmissions & Transfer Cases 10
B 2004 O/d light flashing Transmissions & Transfer Cases 1
L 96 shifting issues flashing od light Transmissions & Transfer Cases 8
C Flashing O.D. light Transmissions & Transfer Cases 19
E 5r55e rebuild P0733, P0735 and no 4x4 low light Transmissions & Transfer Cases 2
D 5R55S o/d light blinking light Transmissions & Transfer Cases 2
3 M5R1 Reverse Light switch Transmissions & Transfer Cases 8
J Ford Explorer OHV 4l OD Light flashing! Transmissions & Transfer Cases 10
B abs light on and 4x4 high light flashing Transmissions & Transfer Cases 15
R O/D light flashing Transmissions & Transfer Cases 4
mfitz725 O/D Off Light Flashes Transmissions & Transfer Cases 5
D 01 exo 4L sohc. O/D Off light blinks Transmissions & Transfer Cases 3
S 2002 Explorer XLT O/D Off Light Flashing Transmissions & Transfer Cases 1
D Flashing O/D light goes off when headlights are turned on Transmissions & Transfer Cases 0
V O/D light blinking, check engine light blinking, burning smell.. PLEASE HELP!! Transmissions & Transfer Cases 1
A 08 4.0L explorer slipping from 2-3 w/ wrench light. Transmissions & Transfer Cases 4
9 Reverse light hook up Transmissions & Transfer Cases 2
B No speedo tacho odo od light flashing Transmissions & Transfer Cases 1
A 2004 Explorer, Bad Noises, ABS & 4x4 Light is on HELP!! Transmissions & Transfer Cases 0
P 2002 explorer flashing 4x4H light and no 4x4 Transmissions & Transfer Cases 0
M 2002 Ford Explorer XLT P0775 error.. no check engine light Transmissions & Transfer Cases 20
Mike65 99 Explorer Sport O/D light flashing. Transmissions & Transfer Cases 8
T Transmission Issues with no check engine light. Transmissions & Transfer Cases 2
T overdrive light Transmissions & Transfer Cases 6
P 99 explorer o/d light flashing Transmissions & Transfer Cases 4
B o/d light flashing Transmissions & Transfer Cases 5
C o/d light blinking, 1-2 shift problems Transmissions & Transfer Cases 0
D OD light flashing/also says check trans Transmissions & Transfer Cases 3
mr cribb 4x4 dash light fix after 1354E to 1354M swap Transmissions & Transfer Cases 8
P 2005 Explorer - O/D light flashing Transmissions & Transfer Cases 2
B 1995 XLT hard shifts and intermittent O/D light flash Transmissions & Transfer Cases 0
J OD Off light blinking Transmissions & Transfer Cases 7
R 2003 Explorer Flashing OD light Transmissions & Transfer Cases 1
M 1999 Over Drive light flashing Transmissions & Transfer Cases 0
R O/D light flashes (sometimes) Transmissions & Transfer Cases 2
Z O/D Light Flashing.. Need Help! Transmissions & Transfer Cases 10
E diagnosing 4x4 hi light blinking Transmissions & Transfer Cases 2
K 2003 - OD light blink Transmissions & Transfer Cases 1
M No O/D light Transmissions & Transfer Cases 0
F 1997 Explorer AWD 5.0 O/D light blinking Transmissions & Transfer Cases 1
S 4X4 light Flashing, ABS light on and Intermitent Cruise control Transmissions & Transfer Cases 4
Similar threads
