99EBEXP
- August 21, 2008
- Arizona, USA
- 99 Eddie Bauer
hmmm so that little white bracket thingy that holds the thumbwheel in place is broken. Its the top half of it that is closest to the copper wire in the pics is broken off of the bottom half which lets the thumbwheel go way out. Any ideas on how to patch that?
I found the perfect solution.
I went to Ace Hardware, and found that the 10-24 nut (#10, around $0.25) fits the threads perfectly!
So I have the nut holding the bottom piece in place, while the plastic wheel holds the other side in place.
The fix took about 2 minutes after getting the nut, and it works PERFECTLY. Plus I can adjust it in the future if I need to.
So check your Home Depot / Lowe's / Ace Hardware etc for the 10-24 nut!!
