Juggernaut31
- February 18, 2013
- Tallahassee Florida
- Now an 01 Explorer Sport
shifting issue 01 Sport - final fix
I posted this in the transmission section about 6 days ago, and haven't gotten a response. I know i hate double posting also, but i could really use some knowledge on this.
I have a 2001 sport V-6 automatic. I don't have flair up, or slipping. the issue is: it shifts from 1st into 2/3 (almost at the same time really quick, then into OD. So it has no power after it shifts out of 1st. You can manually shift it, and it does fine. (pain in the butt with a column shifter).
Also, when at cruising speed, when you put your foot down to pass, it doesn't (kick down) into a lower gear. so you can either (take 2 miles to pass), or manually shift it down.
Any ideas guys?
i have read tons of threads on here, mostly about the flare issue, and even checked youtube. There was a thing on there about a blown valve body gasket, but i trust you guys first. Help please??
Thanks.
Hank.
Any ideas guys?
Thanks.
Hank.
