Shifting Problems - Explorer down | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
kubben
Austin, TX
1974 XLL
Driving home today the Explorer, 1996 4x4 automatic, would not shift out of first. I would hit the gas, engine would rev up really high but not shift. If I slowly pressed on the gas then it would shift some of the time, into 2nd and 3rd.
I pulled into a parking lot and the X went out of gear totally and would not go back into drive, reverse, nothing was catching. I put it into park, let it sit, still would not catch on anything, R, D, 2, 1. I killed the engine, started it back up, and it would shift into D and R then.
Went down the road, it stays in first only and after a long, long time shifts into second then on a turn pops out of D again and will not go back into anything once again. Kill the engine, restart, back into D.
What does this sound like? Tranmission went out? Computer module? Transfer case?
Is the truck throwing any CEL codes or flashing the O/D light? Hows the condition of the fluid? I suspect you have a solenoid failure or failures. Your tranny is a definite for a valve body job. Definately read up on Glacier's 4R55E/5R55E rebuild diary.
The first time the OD light did keep blinking. What does that mean?
Just checked the fluid and it's black. Is black fluid a sign of a specific problem or just old oil?
I have sort of the same problem with mine. I have 91 X and it slowly shifts into 2nd and 3rd. I never had it not go into gear YET but all gears are slow to respond and rpms revs up fast. I have slowly give it gas to move. My fluid is old and dark brown too. Would a valve body job, servo & soleniod changes and fluid & fitler refill solve this you think?
Thanks,
Bob W.
I would do at least a fluid flush and fill. I don't think that the tranny fluid should ever get black before it's changed. Plus it's the cheapest option to do at this point.
