Xylene
- January 7, 2010
- 1998 XLT V8
After all the pain of rebuilding this 302 5.0l engine, I was in the process of installing the alternator accessory mounts and found out that on these heads 3 of the 4 sides contain 3 accessory bolt holes, but one only had 2. Of course the side with only 2 bolt holes requires 3.
So my question is this. Are the heads not really interchangeable? If they are could it be that one of the accessory holes was not drilled out? You can see in the photo that it appears there is a place where the hole should be but it is roughly filled in.
Is drilling this hole a viable option or do I just suck it up and undo everything and reverse the heads? If I do that can the gaskets be reused on the intake manifold, valve covers and the heads (the engine has not be started yet) or do I need to replace them all again?
Thanks
Thanks
