SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
Let me preface this by saying that my A/C compressor has not locked-up, blown-up or failed. I have a pin-hole leaking hose assembly where you can see PAG oil around the rubber hose to metal crimped fittings. I've recharged it a few times over the last year only for the refrigerant to slowly leak out. When I've recharged it would appear that the high pressure side is sitting a bit lower than it should so I've decided to replace the compressor while I change out the leaking hose....it is after all the original 2002 compressor which runs almost everyday here in Florida.
Just for chits-n-giggles, I'll be replacing the receiver/dryer, compressor, high pressure hose assembly and the orifice tube. I'm not expecting to see any weirdness or junk in the orifice tube. Therefore, I do not plan on replacing the condenser and I'll be reusing the evaporator and the other hoses. I doubt the condenser can be flushed because of the very tiny passages but the evaporator should be flush-able as well as old hoses.
Should I bother flushing the evaporator if there isn't any evidence of contamination or metal crude? And, if there's no need I'm wondering how much PAG oil remains in the old components to be reused? I plan to follow the specs on PAG and refrigerant quantity but if there's PAG still in the system because I didn't flush how do I adjust the amount to add?
