roveer
- September 28, 2006
- Morristown, NJ
- 2013 Explorer XLT
After running into a number of pesky problems on my 06 v8 explorer which has 299k miles (I'm the only owner), I decided to give it some TLC. Engine was rough, shifts were hard, trans shudder. So I changed the plugs (fearing one would break), but was successful in getting all 8 out. Changed all 8 coil packs. Oil change, used high mileage oil. Air filter. Engine runs 200% better. Still have hard shifts and trans shudder once it warms up. I bought the lubegard shudder fix and have yet to put it in the trans. One user here suggested that I drop the trans pan, drain, new filter and new trans fluid. I did buy the trans filter and Mercon SP oil. I've been hesitant to do this because the vehicle has so many miles and I've read many stories of imminent failure once new oil is introduced. So I have to make a decision before I put the lubegard in. Change the fluid/filter or don't change fluid filter. Would appreciate your opinions on this. This vehicle has always had a little chirp when changing gears (2-3 I think) and now I notice the chirp a little more on some other shifts. I'm assuming this is probably clutch packs slipping? I don't ride this truck hard any more, I'm trying to see how many more miles I could get out of it. The body and interior is in pretty good shape for it's age and has always been garage kept. I'm in the process of doing wheel bearings and soon the annoying whine will be gone.
Oh, after doing a bunch of late night reading I determined that you should clear the transmission adaptive tables so it can relearn. From what I've read this will go a long way to smooth out the transmission. Ordered the proper scan tool piece (35 bucks) and will use the FORscan software to clear the tables.
Fire away...
Thanks,
Roveer
Fire away...
Thanks,
Roveer
