AlaskanJack
Elite Cabin-Fever Captain
- March 24, 2002
- Centralia, Washington
- 91 , 93 & 01 Sports
Ok so here I go. I made myself the promise that when I got this trail rig that I would do all the work on it myself. So while fixing my brake problem I discovered I had a broken hub and my rotor is just wobbling loose.
I have never done anything other than brake pads and shoe replacement so this is getting into untested waters for me. I have acquired a 91-92 and 91-98 Haynes manual, a 1991 Truck Shop Manual Supplement and a 1991 EVTM. I also got the CD service manual and complete vehicle part number list.
So with these references and my newly acquired $400 Napa rolling mechanics toolbox and tools I get started.
My question is when I go to replace the inner and outer bearings is there any service to do to the hub portion of the axle? How do I pack the bearings with grease? I think I've seen some kits at Schuck's for packing bearings, but are they necessary? Regarding the bearings that are pressed in can I press the new ones in or should I run the rotors to a machine shop for turning, or buy new rotors, and either way have them press the new bearings in?
So next since I will have to do both sides how do I check the upper and lower ball joints for wear? I can't remember if its lifting the tire up? I was planning on replacing all bushings and ball joints in the near future, but since I'm half-way there with the bearing replacement I'll see if they are worn and whether my wallet can afford it.
For my broken hub I am going to just pick up a used one at the salvage yard and then in a few months get a set or Warn manual hubs.
