Should I replace O2 sensors in pairs?
EdmondsXLT
Edmonds, WA
2003 Explorer XLT 4.0 AWD
I just picked up an 03 Explorer XLT V6 that was showing a P2198 code - O2 sensorf stuck rich, Bank 2 sensor 1 - so driver's side upstream sensor. I picked up a new one and swapped it in and the code has gone away. My question is, should I replace the one on the other side as well? Or even the remaining 3? Or just leave them as is until I get another code?
J_C
Florence, KY
1998 XLT 4WD 4.0L SOHC
It's not a safety issue so you can wait, but yeah soon enough you'll probably need the passenger's upstream at least.
Fordfan03
NC
2003 explorer xlt
if it ain't broke don't fix it
EdmondsXLT
Edmonds, WA
Update after a month and a half, no new O2 sensor codes showing up
Drewmcg
Location
Michigan
Ann Arbor, MI
2010 XLT 4WD
2002 XLS 2WD
No need to change 'em in pairs, IMHO.
mountaineer2004
2004 Mountaineer (V8)
IMHO, if you're fixing it yourself, one at a time is good.
If using a mechanic, and paying diagnostic fee, replace in pairs.
J_C
Florence, KY
^ I might do the opposite. Since a mechanic is so expensive for something I could do myself, typically including a part price markup too, at a mechanic's shop I'd only get the one done
If it was DIY instead, while I have it jacked up, under there, with a loaner O2 wrench, I'd pay the ~$30 to get a 2nd sensor and put it on at the same time... might be different if it were a more expensive part.
