Show off your home made tools! | Ford Explorer - Ford Ranger Forums - Serious Explorations
Everybody has encountered a situation where they needed a certain kind of tool which wasn't available (or too expensive). This is when you have to improvise, and get creative. I had this happen a few times. To start off this thread, I was replacing my front suspension components (shocks, springs, upper control arm bushings, ball joints, etc), and encountered a situation where I needed a way to compress the lower control arm, and support it. Here are some pictures to further explain what I did:
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Burns
Moderator Emeritus
Pulaski, TN
1991 Explorer/2002 F-250
Everyone who is lifted knows that it sucks to get the tranny or tcase off easy. So we took out motorcycle jack and made a simple mod for it.
Works well. It safty pins to the jack with the pins that came with the jack to hold the top skids on. So you will only be out the square tube if you have the jack.
Modification to the stand. Forgot to add that we cut a bit of one middle support to allow you to tilt the tranny up or down. I still have to add some more square tube down and across to cover the missing spot.
We also made a fan clutch removal tool.....This is not it but it looks the same. This one is for one of our big mowers.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Burns
Moderator Emeritus
Pulaski, TN
Ill get a pic of the tranny cradle with out anything on it. UPDATE IN POST 3
The wrench is about 14+ inches long. Not sure on any more numbers at the current time. I forgot...lol
Brian1
Albuquerque, NM
1991 XLT
Callsign
KG5BAQ
A few of mine:
Top - axle yoke remover that fits 1310, 1350 and 1410 yokes. Holds the yoke in place while a socket fits inside it to loosen the nut
2nd - Seal driver for replacing the lower power steering seal on a first gen Explorer without removing the box from the frame
3rd - Plane of Bend bracket. Positions a level or degree finder on a piece of tube whil it is in the bender so I know how much the tube is rotated between bends
last - tools for rebuilding a saginaw power steering box. 1 is a spanner wrench for removing the input and the next is a splined connector with a 1/4" drive for using my 1/4" in-lb torque wrench for checking preload (which is adjusted by the bolt on the top cap)
I have also made more stuff like dies for my press, positioning clamps and various pullers
Spdrcer34
Bremerton, WA
1992 Explorer XL
When I rebuilt my M5OD, I had to make a bearing puller.
I couldn't find a single puller that had 12" of reach & pulling length. So I made this:
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
weve made countless dies for the press brake, usually to bend round bar, or to put a radius bend in a piece of sheetmetal.
Recently we made a jig that formed pieces of 7/8 cr soild bar into meat hooks for a local processor.
shamaal
Friensdwood, Texas
91 Mazda Navajo
A home made A/C Schraeder Adapter valve adjustment tool.
When converting from R12 to R134a there is an adapter that screws on to the R12 port that will accept the R134a fittings. Invariably the depressor extension inside the adapter inside is not set right and keeps the Schraeder valve depressed enough to cause a small but persistent leak. A normal Schraeder valve adjustment tool does not fit in these adapters, hence the new tool Dremeled from a drill bit.
After adapter installation, the tool is used to back out the depressor extension in the adapter until it clears the Schraeder valve.
SVO
Moderator Emeritus/Doctor
Moderator Emeritus
Bastrop/Austin, Tx
Turbocharged Navajo LX
Seal removing tool, made from flat steel and a Toyota radius arm
Spare Tire winch adapter, to operate the drop/raise winch with a 1/2" impact
Misc, broken 1/2" extensions, rear diff carrier pins, and what-nots used for drifts or drivers
Cast pipe pieces used for a cooling system flush kit, screw and unscrew the pieces to fit whatever your working on for different radiator hose size
Pipe fitting on the right is for installing rear main seals, the 2" pipe on the right is for installing pinion bearings in a 20ton press (Right Kris??)
2.0 and 2.3 Ford 4 cylinder, lifter removal/install tool, made from flat steel
Misc wrenches cut-up, ground on, and bent (MODIFIED) for reaching hard to get at spots, power steering lines, header bolts, and whatever I couldn't get at, at that time
In the background behind the Lexus ES300 you'll see an "I" shaped wooden fixture, this is used to hold the engine in place while you remove the K-member out of a vehicle to service it, being header install, rack & pinion seal repair, ETC
I have more but we'd be here all day :rolleyes:
Jeff - :navajo:
ShadowdogKGB
Tioga County, PA
'91 Navajo
Clutch Spring Compressor Tool
Basically this shows how to make your own Clutch Spring Compressor. I used 1/8" plate steel for this. You can find it at most welding shops or trailer dealer/repair shops. The rubber hose goes over the all-thread to protect from nicks and scratches.
Below: The small bottom "H" piece was my first attempt so I used it as a base since it was too small. The base doesn't have to be an "H".
Below: Pretty basic stuff really. I used a hacksaw at first but got smart and bought some good metal blades for my Bosch jigsaw. It cuts it like butter.
Below: Just a "T" shape with a hole in it. I should mention that the overall length is 6" total.
Below: Put it in a vise and bend it like shown. It's all eye-balling. This stuff bends ok by hand but some heat from a propane torch and a little beating with a hammer will help.
ShadowdogKGB
Tioga County, PA
'91 Navajo
Fan Pulley Wrench
Advanced Auto Parts sells one for for like 22 bucks or something, which is absurd. Some places have them for as high as 50 bucks!
This is the same thing but without the black paint and the "Made in China" thing. (I'm just guessing they're made in China cuz I bent the hell out of the loaner I used from Advanced Auto).
I used 1/8" plate steel again. It works fine for me but if you have a fan that's stuck real good you could make it out of 1/4" plate steel. I use a regular Crescent Wrench for the Fan Nut. It's a tight fit but it works.
billz260
Tulsa, OK
'94 Sport
Most of mine seem silly compared to these! I'd like to see more :)
I'll see if any of mine will be a contribution.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
billz260
Tulsa, OK
'94 Sport
Absolutely nothing lik those above! Mostly adapters to use funny cominations to drive sockets w/ something other than a wratchet, and other little stuff like that.
I also make lots of small parts out of .062 to .125 plate that i have laying around, like brackets and block off plates, retainers and what not.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
chriswells78
Location
Central Ohio
Powell(Columbus), OH
2013 Limited
I'm always having to get creative, most recently, I used a stock 5.0 Throttle body and a block of wood and a hammer to put the front seal in my motor.
I also made a key for closing the moonroof on my truck because the motor is bad.
My buddy used a garage door opener cable and my pulley puller to get a steering wheel off once too.
RockRanger
Elite Ranger
Fresno CA
86 ranger no more
Callsign
KK6TDL
Thanks I have to swap out my fan clutch in the next few weeks and I will be making one of these.
