There is a tiny 5 amp fuse for those, check that first. The switch has tabs behind it to hold it in, you would need to remove the door panel to get it off easily. There are two screws behind the door handle, and one along the bottom of the door panel. The panel is pressed on with clips around the edge going into the door. Good luck,
