Side Mirrors....STRANGE QUESTION | Ford Explorer - Ford Ranger Forums - Serious Explorations
YourNameHere
Haverhill, MA
94 Explorer
I noticed today that my power seide mirrors don't fully work correctly.
The Passengers side will go UP and OUT, but when I try to adjust the mirror DOWN or IN, it doesn't move,
The Drivers is the same, except it won't adjust IN.
But In on the driver's side and OUT on the Pass side is the same direction on the switch (if that makes any sense).
Is it just the switch?
aldive
Elite In Memoriam
1999 XLT
Strange, but it could be the way the actual glass part attachés to the moving plate. I seriously doubt that it will occur on both sides. Have you had the mirrors apart?
YourNameHere
Haverhill, MA
94 Explorer
Nah, I just noticed it this afternoon.
I'm thinking it's the switch.
Charlie
Wisconsin
2000 Limited
I wouldn't think it is the switch, since the switch seemingly works in both positions. Also, I wouldn't think it would be the mirrors, since it appears both mirrors work in both mirrors. I am thinking perhaps wiring? Have the inside of the doors gotten wet, by any chance?
YourNameHere
Haverhill, MA
94 Explorer
That's just it, the switch only works in the UP and RIGHT.
The LEFT and DOWN functions do not work.
Not sure if the inside of the door ever got wet. It's a 94 and I've only had it a few weeks. Besides, it would take A LOT of water is poured directly onto the wiring to cause it to malfunction
cmfd70
95 f250
This problem of up and in but not down and out is because the armature behind the glass has become unsnapped from the mirror backing plate. The armature will PUSH it in and up but it cant PULL it down or out. Reconnect the arm behind the mirror, it snaps into place on the mirror backing plate.
