Single Click When Starting Up | Ford Explorer - Ford Ranger Forums - Serious Explorations
almondj
NW Colorado
1998 Explorer V8 EB
Hey all,
Vehicle: 1998 Ford Explorer V8 (5L) Eddie Bauer
Sit-rep:
  • Went to class this morning, had no problem starting.
  • Went home, no problem.
  • About two hours later go to start the car, a single click. The music, indicators all work. Fiddle around with the ignition and gas pedal and get it to start finally.
  • Start it again after a few hours and get the same issue, but finally starts.
  • Go to the store and try to start it again, single click like before, but can't get it to start. (Still sitting in store parking lot)
Other details:
Never had this problem before
Vehicle is pretty heavily corroded from salty roads (michigan)
162k miles
All electronics work!
Doesn't die like I've read about in some threads here
Mechanic, dad, and friend says it's got to be a starter. Any ideas?
96eb96
Albany, NY
96 EB V6 OHV 4WD
Hey all,
Sit-rep:
Other details:
162k miles
Starter or terminal corrosion somewhere.
toypaseo
Flunked daycare
outside shovelling snow
................ 96 XLT ™
Sounds like the starter contacts are worn to me.
When the contacts were worn in my Paseo, I would get a single click. Turn the key again, maybe another click, maybe start as usual. Turn the key again, maybe another click, maybe start as usual.
Dash lights would dim, like they do when starting, but no cranking.
almondj
NW Colorado
1998 Explorer V8 EB
The battery gauge barely moves, but that's it. Towed it to the local shop to get it checked out. Will update this thread to inform those with the same problem what to do.
mbarner
Orlando, FL
'02 sport
I have this same issue....I know I need a new battery but I also know that isnt't the real issue. Gonna start small and replace corroded battery cables and hopefully I won't have to work my way to starter. Had a guy in an '01 sport come into the lube shop I work at with the same issue.....his battery was brand new.
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
