Single leaf rear springs | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
codycoyote223
Cody, Wyoming
2000 Explorer Sport
I have a 2000 Sport (2dr) 4wldrv. I've read about sagging driver's side rear springs, which I have. These are single leaf but they are really expensive for new ones. Has anybody just switched the rear springs from side to side and taken care of the sagging on the left side? I'm putting Bilstein's on and I want to do everything at one time.
You can get the 3+1 leaf ones from a 4 door... I think it was discussed around here.
swap to a 1st or 2nd gen 4 door leaf (or 01-03 sport). it will fix the sagging problem, and will also handle tons better
Thanks for the quick replies. I have ordered a set of used springs from a 2000 4dr from a local yard after you recommended them. They will go on with the Bilsteins when they arrive. :D
I swapped in the 4-door leaf packs to my 2-door, it does ride better. Makes sense, basically trading a fixed spring rate for a progressive one.
I followed the recommendations and put on a 3+1 spring pack from a 99 4 door on my 2000 Sport. The difference is incredible-anyone with a single leaf rear spring should do this mod. I picked up both springs for $100, removed by the yard!
