Robert lee
- December 7, 2016
- Simms
- 1992 ford explorer xl
After countless attempts to bleed my master n slave clutch cylinders I found a simple effortless way......this works .....get a turkey baster ( 4.95 all plastic if u want to reuse) remove needle and either replace with plastic tip ( found in millions of tubing products laying around) or don't use a tip.....remove filler from firewall .....take half fluid out....fill baster with brake fluid ....remove bleeder valve on transmission.......place baster tip in hole on filler ...push plunger down to shoot fuel down system ......repeat .....tighten bleeder .....full clutch......if u have a buddy that can shoot the fluid for u so u can tighten bleeder quick u won't even have to bleed again ......I actually din't have a buddy n it requires nothing else.........no bench bleeding no anything
