allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
Slightly Modified-This thread will be for the 1991 4 door 4x4 that I purchased about a year ago. Not only will I be repairing it, I am going to perform some mild modifications. I had seen it sitting out near the field on one of my neighbors property and ask him if he would sell it. He said that he would and I bought it.
Here are a few pictures:
it's been bumped in the front and a fender has been replaced. The left rear side glass had been busted out and I found one at a junk yard for $15-
The receiver hitch was on it when I got it which I was glad to see because I always need a good hitch. Yes that is a Farmall M behind it, a 1947 I think.
It came equipped with the bench seat. All of the seats and carpet are in good condition. Door panels too and I did acquire a gray drivers side front door panel.
It is complete under the hood. When I purchased it, someone had already started removing the A4LD The crossmember was missing however both of the driveshafts were with it and the transfer case was hanging by 3 bolts.
Phase 1 will included whatever the V-6 4.0 OHV engine needs, It is suppose to run and was recently swapped out. Rebuild the A4LD for now and I may go ahead and go through the BW T-1354e transfer case while it is out of the vehicle. I want to perform a 2" body lift and am keeping the lift short enough that the steering linkage wont require much modification and also 1.5" front coil spring spacers which will pretty much just level the truck out. The mild lift should make enough room for 31.1" tires.
Phase 2 it will be a bit more mildly modified. Plans include installing a very mild 302, with a small carburetor with Duraspark electronic ignition. Also a built C-5 with an Advanced adapter kit to hook up to the BW T-1354e transfer case. Very basic. I have searched and studied online and got it down to the basics. Double hump pan, '88 Mustang convertible motor mounts reversed. '97 5.0 Ex/Mountaineer headers to clear the steering and box. Remote oil filter relocation hardware to clear the steering box. Also some radiator support modifications to house a bigger, better radiator. And a few other things for sure.
Added: I meant to mention at the beginning of this thread what I will be using this 4x4 for. We occasionally canoe, camp or take the flat bottom boat out to fish a little. Most of the time the .access to the canoe boat launch spots are in good shape however sometimes the paths are a little wet or muddy. The mods should be enough that we can get in and out. I already know that our 2WD Explorers with P23575R15 Wranglers get stuck real easy. Once the treads get full of gooey mud, that is it. This should be some better between the 4WD and a little more aggressive tire/tread.
