thewishkah
- August 17, 2004
- Brooklyn New York
- 1994 explorer xlt
Ok so yesterday I was driving and I noticed the rpms were in the 4500 range and I was only going 30 mph so I let off the gas and as I did it dropped in rpm's then it finally dropped into 2nd? then I went to park it and when I went into reverse and hit the gas i went no where then banged into reverse at like 2000 rpm. Is it about to go? if so when it goes is it worth it to go to the 700r? and how much would a shop charge to do the switch over with the kit, another rebuild is going to cost me 1700$ and it would be # 6 I cant deal with this horrible transmission anymore. This truck is getting on my nerves too 2000$ within 2 weeks= water pump, 4 tires, brakes,fan clutch, upper lower ball joints, radius arm bushings and mounts, and now this ugh sorry for venting. Any advice/ recomendations would be greatly apreciated
thank you . Jon
thank you . Jon
