RickyG
- September 28, 2019
- Texas
- 2020 Explorer Limited
- Callsign
- I
It’s probably just fuel flowing over the top of the baffles. If a baffle was broken, and flopping around your tank, you’d know it. It’d also get worse the less fuel you had.
I found this on the internet do you think it's possible this could be the same problem with the 2020 Explorer?
https://ford.oemdtc.com/TSB/18-2003.pdf
If the straps are permitting too much movement of the tank, it can amplify the movement of the fuel which would create larger waves in the tank or would create waves in the fuel that collide excessively with each. Both would lead to sloshing around.
