cratz1990
- September 30, 2022
- Jackson, Michigan
- 2014 Ford Explorer XLT
So here’s what I got going on. 2014 Ford Explorer XLT. Sat for about a week, ran perfect before that. Get in it and it’s a slow weak crank and does not start. Figured it was battery so I changed it. It began to slow crank again then no crank. Volt meter said 12.3 on my battery. Throwing several error messages like “check battery charging system” “parked on an incline” “low gas” (it has half a tank). Check engine light is on but there’s no code when hooked to code reader. Next step I took we replaced the starter. Hooked it all back up and same issue except there’s no crank and the starter is clicking as if it’s getting juice. Volt meter says 11.4 v on the starter. Checked fuses. Grounds are connected with slight corrosion but nothing crazy. Would appreciate any help at all with this one lol. Thanks in advance!
