smegun
- April 3, 2013
- florida
- 1994 ford explorer xlt
I have bogs for passing power there is inefficiency when hitting pedal I doubt it is the fuel pump because I have replaced mine with new unit have done most tune ups ex: plugs wires thermostat pvc maf clean new alternator platinum dubl platinum seafoamed clean upper egr
truck runs good at times until my makeshift patch pluging holes in my egr tube burn through (jbweld dosnt work for long but long enough to get the picture) after the truck settles with the brain and all its respiration and solid EGR tube the program will settle and it will burn the fuel correctly and excellerate more linearly and lose bad vibrations that simulate friction even get a little low gear tire spin
small holes in egr tube forces poor advance on fuel burn the brain kicks back and seems to run ruffer
it needs all the air it was designed for little margin for error currently im replacing the egr tube as above finding air leak that forces bad advances and passing excelleration delays
all worries of cat or electronics were not as effective as plugn some holes check your egr tube it shouldn't be blown air also make shure you vacume tree is tight ......maf clean air box clean vacume tree tight egr tube solid no exhaust leak at least before the cat correct pressure has to come back to the egr and sensor or change the flash and plug the egr somehow
someone post a link for 4.0 litre without egr I know the engine exists or similar brain flashes
:roll:
egr tube needs to be soaked a few nights with penetrating oil they shculd of made all that hardware out of brass it a nut worth commiting
:roll:
