2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
waste spark ignition
The second generation Explorer's have a waste spark ignition system. Two plugs fire at the same time - one of the compression stroke and one on the exhaust stroke. Waste spark ignition systems are less expensive to manufacture. Ford claims their system reduces pollution by firing on the exhaust stroke but I doubt that the mixture is even combustable.
Because one section of the ignition coil fires two plugs (one of each bank) the current flow thru the plugs on Bank 1 is opposite to that on Bank 2. The direction of current flow impacts wear on the plug. Each time the plug fires a small amount of metal is removed from one electrode and deposited on the other electrode. The factory plugs in Bank 1 used to be different than the plugs in Bank 2 and had different part numbers. I purchase either double copper or double platinum electrode spark plugs for my Sport. That way it doesn't matter which bank they are installed in.
