Not only will you need an alignment, but you'll also need to install a set of camber adjusters before you bring it in to the alignment shop (because camber can not be adjusted with the stock "cams" and "cam bolts"): http://www.explorerforum.com/forums/showthread.php?p=2140432#post2140432
