Sn0border88's SAS'ed
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
your truck and mine are totally different, so you really cant compare.
184baller
vancouver bc
'96 xlt 2' and 33s
questions
this is the kind of lift i wanna do to my 96 can you give me lots of info on how you did this leaf spring brackets ,placements mesurements any info would be good . im kinda new and learning . i was just gonna take the front end off of a jeep yj and make it fit .
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
well, you can either do it shackles in front or in rear, I did in front. Most guys go in rear because it will drive better on street.
With my axle I needed to outboard the springs from the frame a bit so the spring perch wouldnt be ontop of the differential, its a little on the side of it now.
read through my SAS thread, theres lots of good info in there. Lots of pics too around page 9 I believe.
Spas has a 2nd gen on leafs so hers may be more helpful to you, but for the most part our trucks design is the same.
R New to the forum and have sas'd explorer Solid Axle Swap Registry 9
S SAS Mountaineer undrivable Solid Axle Swap Registry 29
johnny499 '98 mountaineer v8 hp44 sas soa on 35's Solid Axle Swap Registry 7
2TimingTom '97 XLT Dana 30 SAS Solid Axle Swap Registry 24
1-MEAN-X 1-MEAN-X's '01 Sport SAS Registry Solid Axle Swap Registry 11
01STrunner 01STrunner's Sport Trac D44 SAS/SOA Solid Axle Swap Registry 79
S 98 sport SAS help Solid Axle Swap Registry 1
D 94 ex sas Solid Axle Swap Registry 13
9 here is my sas ranger on 35's Solid Axle Swap Registry 4
janderson4010 bronco II 3link d30 sas Solid Axle Swap Registry 10
M My SAS 97 Explorer Solid Axle Swap Registry 15
W 99 EB x SAS D44. Solid Axle Swap Registry 55
R List of Useful Threads Ford Explorer & Ranger Solid Axle Swap - SAS - Registry Index Solid Axle Swap Registry 31
F 91 sas swap Solid Axle Swap Registry 12
B 1999 Ranger SAS (Dana 44/Ford 9 Inch) Solid Axle Swap Registry 18
J The Unappreciated X SAS Solid Axle Swap Registry 11
T My 2nd gen ex SAS Solid Axle Swap Registry 31
94 Crawler 94 Supercab Splash SAS Solid Axle Swap Registry 23
CodePoet 93 xlt sas Solid Axle Swap Registry 7
MEANEXPLODER 91 xlt dana 44 hi-pin sas Solid Axle Swap Registry 17
N '91 Ranger XLT SAS Solid Axle Swap Registry 2
chad551 2002 Sport Trac SAS Solid Axle Swap Registry 141
S 92 ford ranger sas Solid Axle Swap Registry 9
L Lifeguards sas registry Solid Axle Swap Registry 23
R Old member first time posting. My SAS. Solid Axle Swap Registry 71
SVO42 SVO42's 1-ton SAS Solid Axle Swap Registry 121
S 93 x SAS Solid Axle Swap Registry 52
D Dangeranger SAS done Solid Axle Swap Registry 29
CheapThrillEX SAS and New Family Wheeler Solid Axle Swap Registry 19
mtwheelin mtwheelins sas Solid Axle Swap Registry 15
IZwack IZwack's SAS Registry Solid Axle Swap Registry 10
F Fat Cat's 99 SAS Solid Axle Swap Registry 80
Spas Captain Morgan, '95 D44 Sas Solid Axle Swap Registry 199
Burns 1991 Full Width SAS 44/9 Solid Axle Swap Registry 31
9 my 97 ranger sas,302 powered. Solid Axle Swap Registry 11
Stic-o '99 Full width SAS 44/ 8.8 Solid Axle Swap Registry 28
section525 Section525 - Explorer V8 D44 SAS Solid Axle Swap Registry 38
Kirby N. SAS Steering? Buy Mine- Complete with Heims and DOM Solid Axle Swap Registry 0
J johnny5_72's 89 Ranger Dana 30 SAS Solid Axle Swap Registry 30
9 9sport6's Fix aka sas Solid Axle Swap Registry 40
S SAS Pics w/ Questions Solid Axle Swap Registry 53
F FullFootNotch's SAS on 38s Solid Axle Swap Registry 24
S S10slayer's 99 ext cab ranger sas on 36s Solid Axle Swap Registry 12
-=DaemoN=- Daemon's SAS Solid Axle Swap Registry 30
F littlefoot sas on 38's DONE!!!! complete with baptism pics. Solid Axle Swap Registry 53
S '97 Ranger SC, D44 SAS... Solid Axle Swap Registry 9
Y Yomies D30 SAS Solid Axle Swap Registry 105
J Jefe's 2000 XLT SAS Solid Axle Swap Registry 8
madmike MadMike's 93 SAS Solid Axle Swap Registry 49
gavin 1986 Bronco2 SAS Solid Axle Swap Registry 5
Similar threads
