The #1 Ford Explorer enthusiast resource for over 25 years!
Performance Upgrades - Maintenance - Modifications - Problem Solving. Covering the Explorer, ST, Lincoln Aviator, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Aerostar.
Who makes a SOA kit that that will fit the Explorer? and how much lift should I expect to get with it?
Thanks
i think a lot of people on the board just do it themselves....it's just new brackets/perches, a total of around $35 if i remember, should give you around 4-5", hope this helps....did you search?
Skip superlift, I wish I would've because it does need to be welded. You can buy some nice antiwrap perches and get shock mounts welded on for less. You can even ditch the rear swaybar and bolt on some shock mounts too. Look at http://www.mountainoffroad.com/ for the axle perches.
