How to: - SOHC V6 Camshaft Timing | Page 4 | Ford Explorer - Ford Ranger Forums - Serious Explorations
How to: SOHC V6 Camshaft Timing
mrb09c
Tallahassee, FL
2000 Ford Explorer 4X4
That's what I was thinking too, I made sure the traction side was tight.
Join the Elite Explorers $20 Get rid of the ads!
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
. First register on the forum, then join the Elite Explorers to get rid of the ads!
2000StreetRod
Staff member
Moderator
Greenville, SC
00 Sport FI, 03 Ltd V8
The spring in the tensioner is too weak to overcome the slack on the traction side of the chain resulting from valve springs. When there is oil pressure in the tensioner the slack is overcome and the chain on the traction side is taught. Timing the camshaft without using the tensioner tool or an equivalent procedure resulting in a taught chain on the traction side will result in the timing being a few degrees off. It probably would not be detectable for normal driving but could affect peak performance. Many Mustang owners time the camshaft to advance the timing about 5 degrees to improve max rev performance at the expense of idle smoothness and low rpm performance.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
Ditto, the process of setting the timing is based on the intended chain conditions, the length of the chain given known tensioner length. The stock tensioners change length given chain tension, the tool(dummy tensioner) does not change length, thus maintains chain tension expected to set the timing.
Thanks Dale for the Mustang reference. I'm planning to set mine soon after locking TDC by a proper TDC piston stop tool. I hadn't yet searched to see if there is a best timing to use, such as 5 BTDC. I don't want any loss of bottom or mid range power, I don't need 5500rpm power.
allmyEXes
Location
Lickskillet
No. Alabama USA
1997 Blue Ex 4.0 SOHC
Callsign
KAGG 3611 (CB)
So what is the length of the dummy tensioner? From the point that it contacts the head to the end of the plunger?
ICoull
Castlegar, BC
2003 Explorer & Aviator
It is 2 5/8” from point of contact to the end of the tool. Remember there is no (spring loaded) plunger involved, it is solid for its entire length.
Corrected below... there is a heavier spring (relative to the real tensioner’s) inside this install tool, that preloads the traction side of the chain when setting timing. Thnx for the correcting info. Ian
allmyEXes
Location
Lickskillet
No. Alabama USA
Callsign
KAGG 3611 (CB)
Thanks ! that translates to 66.675 mm. I have been wondering what it was for a few days now. I installed an adjustable tensioner meant for a RZR a few months back in the right head and it has been working well.
2000StreetRod
Staff member
Moderator
Greenville, SC
The compression ring is 0.060 inches thick so the distance is 2.687 - 0.060 = 2.627 inches. Before I purchased my OTC 6488 timing tool kit I made my own "precision" tensioner using an old spring/hydraulic tensioner.
I cleaned the oil off and then applied epoxy to the area between the arrows.
donalds
Location
Stem
Nc
1999 ford explorer sohc
The dummy tensioner has a heavy spring in it
Install it at full length you will break your guide
2000StreetRod
Staff member
Moderator
Greenville, SC
