bats
- October 30, 2009
- NY
- 88 Bronco II
Decided against doing a SAS on the Bronco so clearing out some parts.
First up are a set of mid 80's fill size Bronco radius arm mounts. Some surface rust but still solid.
$80 for the pair.
Also selling the Early Bronco Dana 44 I was going to put under the BII. It is SEMI COMPLETE. You will need everything after the knuckles (hubs, brake setup, lockouts).
Here is what comes with it:
Axle housing with freshly installed Yukon 4.56's
Stock radius arms with the rubber wedges
Stock axle shafts - need u-joints
Stock tie rod setup - worn out, for mock up use only
Stock Knuckles
Asking $250 for the axle. Make me an offer. Located in 11722 which is Suffolk County, Long Island NY. Willing to meet in tri-state area within reasonable distance.
$80 for the pair.
Stock Knuckles
