ootdega
- April 8, 2017
- Salvage 1999 Mountaineer
Hi, this is my first post here. I'm usually on GrandMarq.net, but you guys probably know more about this. I looked around and this is the most active and knowledgable place I saw.
I recently bought a 99 Mountaineer 5.0 AWD for $450. It's a salvage title, hit a tree and took out pretty much everything in front of and including the front frame. Engine is perfectly fine, electric fan looks like it should work too despite the power steering pulley digging into it.
I plan on taking the engine, transmission, ECM, wiring harness, fan, fuse box, rear brake backing plates, front seat air compressors, tires and center caps off of it. I will use all of these in my car later on.
The main thing I wanted to ask about is what I will need to know to remove the wiring harness. Mainly the engine and transmission harnesses, but other parts of it would probably be useful for the extra wiring. Everything else should be pretty straightforward, but any input would be appreciated.
It's currently at someone else's place, so I won't get too many cracks at it before I'll have to scrap it.
