Kath777
- May 19, 2017
- 1992 ford explorer 4wd
Caution is advisable here, as mis-steps using a series-wired ammeter can instantly destroy it. Use highest range setting first, make sure no one messes around with lights, etc.best i can do is give you a possible diagnostic method. if you disconnect the positive terminal and hook a multimeter between your battery and the lead with the meter set to amps with the vehicle off it will show you the draw. start with your accessory fuses such as a/c, radio, and other non essentials and pull each fuse one at a time. when you see the draw drop the most the electronics you just pulled the fuse for may be the culprit. this isnt a foolproof end all diagnostic but it is one way to find certain types of parasitic draw. outside of just taking geusses its the best i can offer at the moment.
Thank you, I will try this today.best i can do is give you a possible diagnostic method. if you disconnect the positive terminal and hook a multimeter between your battery and the lead with the meter set to amps with the vehicle off it will show you the draw. start with your accessory fuses such as a/c, radio, and other non essentials and pull each fuse one at a time. when you see the draw drop the most the electronics you just pulled the fuse for may be the culprit. this isnt a foolproof end all diagnostic but it is one way to find certain types of parasitic draw. outside of just taking geusses its the best i can offer at the moment.
what about when your meter on the dash swings and gets stuck past the off markThere was something peculiar, I don't quite remember all the details... I think Rick wrote about it a few years ago, where the alternator will not charge if the dashboard charge warning light is burned out. Be sure the light comes on when you first turn the key to ON before starting. I think Drakon is giving you great advice, I'm just saying don't automatically assume the system is charging, I would test that too.
Then you pull your cover off your cluster and fix it. Or, use a multimeter directly on the battery.what about when your meter on the dash swings and gets stuck past the off mark
