Brandon96
- September 6, 2008
- Central Virginia
- '96 XLT 4.0 OHV
Ok, this past weekend I did the Seafoam for the first time (gas, oil, and brake booster), that may have something to do with this. Since then I've run the explorer down to empty (from half-tank) and filled up last night (for 33$ woohoo! I can afford to drive again!) and on the way to school this morning I ran into a problem. I'll do my best to explain this, but, when hitting the gas from a stand still the engine didn't make any harsh or noticble sounds, it just felt like a one or two cylinders were just, not popping if you will, kinda as if the gas going to those cylinders was water. It took a little bit more pedal pressure and a few more RPMs to correct itself. It didn't feel like the timing or anything was off, it just felt like a cylinder was underpowered or something. No clicking noises or awkward sounds were detected, but definentally felt like a missfiring cylinder. AND the engine light went on, almost forgot that.
I DO have one cylinder that burns hotter than the rest, but it makes a loud click or knock when the spark plug begins to go bad, and all I do is replace the plug, but I just got new plugs and new wires not 2k miles ago, so i'm almost sure as heck it's not that. What could this be?
