lonestar
- August 29, 2001
- lou,ky
- 91 XLT, 02 XLS
Calipers do not retract. The piston simply comes out as the pads wear. The pads typically maintain contact with the rotor, the squeezing force just releases. You should see virtually no movement in the piston or pads when the brakes are applied and released, you might notice everything tighten-up, that's it, the piston does not retract back into the caliper.jgilbs said:piston wont retract to be flush with the caliper body. is this normal?
Quite possilbe. When applied, the pads may flex to make full contact with the rotor, but when released, the pad becomes "wedged". You could try to sand them even, or just drive them about 100 miles or so and they should straighten out. I wouldn't worry too much, unless they are so tight that it pulls.jgilbs said:maybe their worn unevenly, causing them to not be square to the rotor.
