mjjstang
- December 2, 2006
- 97 4x4 SOHC
Hi, I have been doing a lot of searching and educating myself on the front end of my 1997 SOHC 4x4 110k miles, but there are some things that I want to throw out there for reaffirmation.
Basically, I am pretty confident my diff is leaking from all 4 spots. (cover, 2 axels, and pinion). I also have an ABS issue that I am hoping is just the rear sensor. (parts on the way to diagnose that issue. Hoping it is rear and not either of the fronts.)
I have decided that when doing this work, I would do the ball-joints and other things that are easily done now.
So to start, with the differential:
1. I have a Dana/Spicer 35, and not a IFS correct?
2. In addition to replacing pinion and both axle seals, should I replace bearings or bearing and race? or should I just worry about seals for now. (I just don't want a situation where by replacing certain things like bearings, and not the axles themselves, I would be doing more damage?) I am hoping that there is no major wear on the shafts, but this leads me to another issue.
3. I have found all types of parts online, but I am not getting a good idea of what axle shafts are in the diff itself. Pictures from a factory manual aren't helping, and as far as I know, the interior axles ride on the bearings correct? or do the CV shafts take the brunt? If the interior axles are the ones that will be worn down, does anybody know part numbers, I might as well just replace these.
4. To replace the U-Joints and boots, etc will cost about 20 per side. New Half-shafts are about 50 a piece. I have no issues with them now, but I figured for 50 each, should I just get new CV shafts and call it a day?
5. If the ABS problem turns out to be from the rear sensor, then I was thinking about leaving the front hubs alone, and just replace all 4 ball-joints. Without spending much money, are there any cheap things I should do with the spindles/hubs that would improve life, and not require purchasing a whole set? If the ABS is not fixed by rear, then I think I will just buy 2 new hubs with ABS installed.
6. I think my alignment is ok, but I figured I would get it done anyway, which would give me a good reason to throw on new outer tie rod ends. There shouldn't be anything else necessary up there that would affect alignment would there?
I just want to make sure that while I am up front, disassembling everything, that I am getting everything that I can to improve the life of the car. I am going cheap here, but I will pay for things like moog joints, like I said, I am trying to maximize the life as well. I just really don't have reason to do this in the first place, other than trying to stop fluid from leaking out of the diff. There is no immediate issue and the car actually drives pretty swell, we added a zerk to one of the ball joints a couple years back, that was making all sorts of noises, so it will be nice to freshen up the FE, but I am in no dire need to spend lots of cash, plus I will be purchasing some tools that I should already own by now, (pullers, removers, press, etc.)
I realize a couple of these questions could be searched better, but I have been here all day trying to get the info I need, and I think I am just about worn out. Thanks for any information I really appreciate it.
