spacer install
MCD04EB
Oklahoma City, OK
'04 Eddie Bauer
hey everyone, I know this question has probably been answered already but i am just too tired and worn out to search for it.
We were working on the front part of the lift for my explorer, and we got the strut out, spacer on, and strut back in but we can not get the strut compressed enough to get the strut lined up to the lower a arm to bolt it back.
what has everyone done to get them compressed enough?
And another question, how does everyone get the ball joint separated from the knuckle?
do i need to get a press to get it out?
because we tried everything we could think of to try and get it out without damaging it.
sorry for the long post, and thanks for looking.
gamecocks
Greenville, SC
2002 Eddie Bauer
take a hammer and hit the metal around the ball joint ( not hard, just firmly tapping it) that'll break it free and fall right out ive done it more than once...
as for getting the strut compressed, once you get the upper BJ loose take a pry bar and pry down on the Lower Control Arm
Ronin8002
Virginia
2008 XLT Ironman
put a jack under the lower control arm and jack it up until the strut is compressed as much as possible (you'll be lifting the truck up when that happens. Then loosen the nut on the upper ball joint and tap that bolt with a hammer and it'll pop right out of the knuckle.
As Gamecocks said, when you install the spacer on the strut, bolt in the lower part of the strut, then bend the lower control arm down enough to swing the top part of the strut over and fit it into the mounting area. I just put one foot on it and put a lot of weight on it and that did the trick.
To reconnect the upper control arm/balljoint to the knuckle, put your jack under the lower control arm and compress the strut as much as possible as you did before. You can then use a ratchet strap or muscle power to bend the upper control arm down the rest of the way to fit the balljoint bolt into the knuckle.
MCD04EB
Oklahoma City, OK
'04 Eddie Bauer
hey thanks gamecocks and Ronin for the quick replys. Its too late tonight but tomorrow I will get out there and tap around the ball joint and then connect the bottom part first. Thanks guys! will let you know how it goes!
Kazer
Sneads Ferry, NC
2001 Excursion PSD
Just my expirence, to compress the strut to get it back in I fist bolted the bottom of the strut to the lower control arm, then using a 4 foot 2x4, I put the wood on the lca and angled it to the ground, stood on the board and put my shoulder inside the wheel well. Push down with both of your legs on the board and push up with your shoulder, then using your free hand, swing the top of the strut and spacer into the top strut mount. Proceed to beat with rubber mallet untill its seated properly
MCD04EB
Oklahoma City, OK
'04 Eddie Bauer
Thanks man! i actually did that last night, i bolted it in the lca first then my dad stepped on it while i pushed it into place. im about to go take some pics of the front half on
T BTF Spacer Install Issues Modified 2002 - 2005 Explorers 0
S Truxxx front spacer install Modified 2002 - 2005 Explorers 10
B BTF spacer/ KYB install issues. Modified 2002 - 2005 Explorers 13
B How To: BTF-Fabrication Spacer Lift Install Modified 2002 - 2005 Explorers 2
H Roadbully Spacer Lift Install Tips. Modified 2002 - 2005 Explorers 8
G Strut + RB spacer install HELP!!! Modified 2002 - 2005 Explorers 12
B custom spacer install gone awry $#^! Modified 2002 - 2005 Explorers 14
Subieboost Coil spacer lift hack Modified 2002 - 2005 Explorers 1
M Spacer lift rear 1,75 “ + front 2,25” Drawings Modified 2002 - 2005 Explorers 4
firefly1246 ?? 2.0 Front/1.5" Rear ebay lift, Quoted Lift vs Spacer Thickness Modified 2002 - 2005 Explorers 5
K 3in spacer lift in front only? Modified 2002 - 2005 Explorers 7
G Ideal tire size for BTF spacer+UCA and 2" body lift? Modified 2002 - 2005 Explorers 7
J Lift spacer search Modified 2002 - 2005 Explorers 4
G Extended sway bar links for 2"spacer lift Modified 2002 - 2005 Explorers 5
S Spacer Lift??? Questions Modified 2002 - 2005 Explorers 22
K Coil Spacer Accessory Modified 2002 - 2005 Explorers 0
K Coil Spacer Questions 02 Explorer Modified 2002 - 2005 Explorers 3
S Traxda Spacer and Wheel Alignment Spics? Modified 2002 - 2005 Explorers 0
B 285/75/16's With Just BTF 3"/2.5" Strut Spacer Leveling Kit? Modified 2002 - 2005 Explorers 2
Mr. Truckles Uniball Tapered pins (stud,spacer,exc) Modified 2002 - 2005 Explorers 0
0 2006 explorer spacer on a 2003 explorer Modified 2002 - 2005 Explorers 2
Brandon@BTF-fab Open letter for everyone waiting for spacer lift Modified 2002 - 2005 Explorers 3
R spacer lift dimensions? Modified 2002 - 2005 Explorers 3
G Rear coil spring spacer Modified 2002 - 2005 Explorers 0
C How big of a spacer do I need to fit 15s on my v8 03 explorer? Modified 2002 - 2005 Explorers 12
G btf spacer lift ball joint issues Modified 2002 - 2005 Explorers 4
S Strut spacer alternatives, taller strut, strut extension Modified 2002 - 2005 Explorers 2
M Xfer Case or Extended CV Axles for spacer/UCA Lift Modified 2002 - 2005 Explorers 4
D Where can I get a throttle body spacer? Modified 2002 - 2005 Explorers 23
C Explorer 02 Spacer lift questions Modified 2002 - 2005 Explorers 14
F Spacer Measurements Modified 2002 - 2005 Explorers 5
B spec for spacer build needed Modified 2002 - 2005 Explorers 12
P Struttek and btf spacer? Modified 2002 - 2005 Explorers 7
T wheel spacer Modified 2002 - 2005 Explorers 0
4 Want a pattern for 02 strut spacer Modified 2002 - 2005 Explorers 0
9 Truxxx spacer lift? Modified 2002 - 2005 Explorers 4
Kazer spacer lift, rear lower control arm Modified 2002 - 2005 Explorers 9
B need specs for spacer build Modified 2002 - 2005 Explorers 3
A front end squeaking after spacer lift Modified 2002 - 2005 Explorers 31
S BTF Spacer lift Modified 2002 - 2005 Explorers 10
0 Spacer lift, 265x70r17 tires, what wheels? Modified 2002 - 2005 Explorers 4
F Wheel Spacer Questions.... Modified 2002 - 2005 Explorers 14
T help! btf spacer lift question Modified 2002 - 2005 Explorers 3
S coil spacer removal? Modified 2002 - 2005 Explorers 1
Jager How are your Spacer Lifts doing? Modified 2002 - 2005 Explorers 11
S Spacer Lift Dimensions Modified 2002 - 2005 Explorers 2
Turdle BTF Fabrication Explorer Lift Coil Spacer discussions Modified 2002 - 2005 Explorers 277
R Sway bar spacer Modified 2002 - 2005 Explorers 6
C Mustang rims - yes? no? offset? spacer? Modified 2002 - 2005 Explorers 17
J spacer lift and camber Modified 2002 - 2005 Explorers 8
Similar threads
